- May 6, 2001
- HOT 'n Arizona
How do you adjust the RAM speed on these boards?
OnDborder (Aug 01, 2001 09:25 p.m.):
TranceBear (Aug 02, 2001 02:00 p.m.):
The first thing I did with my setup was change that jumper on the M/B to read 133mhz FSB. Since my chip had a 100x2mhz FSB I was able to post at 1333mhz. Not all these chips can handle this. Did you not find the clock freq. option in the BIOS?
OnDborder (Aug 03, 2001 03:44 p.m.):
Ok, I didn't know that controlled the RAM speed.
So then, what is "DRAM Timing by SPD" in the "Advanced Chipset" in the bios?
TranceBear (Aug 03, 2001 04:22 p.m.):
that will allow the BIOS to control your memory settings, right now the only way I can get 4-way interleave is checking this yes. When my new Ram comes I will shut this off and do this in the registry with WPCREDIT.
