Msvcrt.dll ?
minoukat
Ottawa, Ontario
I'm trying to install UT demo, and after it finishes unzipping and actually gets to installing, it says MSVCRT isn't compatible with Win32s or something like that. What's going on ? I've been getting this error pretty often lately, and it's starting to **** me off ...
redduc900
Inactive Moderator
Portland, OR
You may want to try running the System File Checker (SFC) minoukat, since it's possible the msvcrt.dll file has been overwritten with an earlier version (the UT installer is looking for a newer version of the file?). Start | Run | Type cmd and hit OK | At the command prompt, type sfc /scannow (after inserting your W2K SP3 slipstreamed install disk) into the CD-ROM drive. ;)
