If one or some could help me determine the best direction to go here I'd be most appreciative.
Actually there seems to be a few multi-channel controllers now which do 3-pin, but also have at-least one channel for PWM fans.
Nothing I've seen that avoids using a bay though unfortunately
So no need for the self-build route, but I do get that you guys like doing this stuff for fun!
Do you realise there's a few pre-built controllers out there (some that aren't bad quality) that can do this now?
So upon closer inspection there seems to be some pre-built options, BUT ALSO, if I understand correctly...
Martinm210 described a circuit one can use in conjunction with their MB, so that one can use their MB to control PWM & non-PWM fans, even high wattage ones!
My mobo may actually have just enough fan-headers (2x 3-pin and 2x 4-pin), with enough juice on the 3-pins for multiple AP-14/15's*.
If anyone knows what he may be talking about, plz can you let me know!?
*update*
I misunderstood him, anyway it's easy enough to connect the the +/- wires of the higher draw PWM fans directly to the PSU.
Should I decide to go the MB route initially....
You're prolly right, if I check their spec. page I should be able to verify whether they're PWM or not.
Even if they're not, I'll have at least one PWM >3000RPM fan, so it'll need to be accommodated somehow.
This seems to be changing with the release of these higher-end Nidec 25mm fans, which may well offer the trifecta!?
*UPDATE, it seems my MB only has the following:
1x CPU fan-header (PWM)
1x chasis fan-header_1 (PWM)
1x chasis fan-header_2 (3-pin)
1x Power fan-header (3-pin)
I was hoping there'd be more fan headers in-total, but at least there's my requisite minimum of 2 PWM headers.
[proposed layout]
I guess I could have the 2x AP-15's (maybe 4x) for the Rad. coming-off the CPU fan-header? (may not be possible if AP-15 aren't PWM)
Two of the three (1 will be donated) >3000RPM PWM GT's I'm importing could sit on chasis fan-header_1?
That's assuming the mod to ones MB martin was talking about is possible, otherwise their current draw would be too high right?
If it is possible, then eventually they could even sit on the CPU fan-header, replacing the 2->4 AP-15's.
For the remaining two 3-pin headers I'll sit 1->3 (total of no more than 6, probably less) AP-14's?
If the CPU fan-header can't take the AP-15's, I may have as many as 5 (3x AP-14 & 2x AP-15) fans coming-off each of these headers!
This isn't ideal, aside from the fact that I may not be able to adjust fan speed from these headers, independent control/monitoring of these two groups makes sense.
Plus I'm not sure if these two headers could handle that many fans (of that draw) on them anyway...
[/proposed layout]
Are 3-pin headers essentially linear voltage controllers (i.e. rheostat/bus) that can run 3-pin fans at 12v or less?
Or can they only run non-PWM fans at their rated top (12v) speed?
Can anyone advise if this configuration will be possible with some "tweaks", or is a dedicated controller looking necessary?
*EDIT* Perhaps a better proposed layout is:
[proposed layout]
2x >3000RPM PWM GT's (model YTBD, prolly the 5400) each sitting on their own PWM header, with their +/- going direct to the PSU?
Then I could put the up-to-4x AP-15's on one of the 3-pin headers, & the up-to-6x AP-14's on the remaining 3-pin header?
[/proposed layout]
Would the 3-pin headers take the load, or would some of the GT's on them have to be rigged direct to the PSU?
Does this all sound too clumsy, is a dedicated controller looking to be imperative IYO?
I'd rather not have something that uses a bay, but would still like RPM/voltage feedback & at least auto-control if possible.
I'm just a little stunned though...
That there aren't any pre-built fan controllers with several channels integrated of the kind Bing demonstrated.
So that one can manage several PWM fans at once, & get speed feedback etc.
Ideally one that can handle a mixture of PWM & non-PWM (4-wire or 3-wire) capable fans if needed.
Surely there's something on this planet that one can buy? Ideally one that needn't be mounted into a 3.5" or 5.25" bay!
When my San Ace fans arrive, and when I decide exactly what fans I'm going to put in my case and where, I'll be building a "proper" fan control unit with designated channels for each fan. There will be only one pwm circuit because I'll only need one San Ace fan (for the CPU cooler) and the rest will either be simple on/off switches or linear voltage controllers courtesy of bing.![]()
So like you I will probably have a mixture of PWM and non-PWM fans.
Is there not anything pre-built to accommodate for this?!
If I can get away with my motherboard accommodating all this without any massive caveats than I'd greatly prefer that.
*update*
I'm not sure. If the scythe GT fans were PWM I'd consider it a bit pointless, seeing that they are already very quiet at their rated speed, nullifying (imho) the requirement for speed control...moreover they are available in different speeds anyway.
The best course of action is to choose what you want most from the fans - versatility, performance, or silence. Very few fans offer all three (which is where the controller comes in) and your best bet is to go for a compromise.![]()
[proposed layout]
[/proposed layout]
[proposed layout]
[/proposed layout]
