I've seen people on the 3870x2 use the GPU2 client. I've also hit this issue if my shortcut had the wrong "start in" directory.
Thid, I think jaxstraww is correct. When performing this proceedure with ATI cards, that file is not needed.
I'm currently working on getting my 4870 twins setup in Vista x64, I've got one running fine, the second GPU is not however. After reading your guide, I've got a few ideas on how to fix the problem. I'll report back soon.
Thanks, Thid!
I saw very little increase (10 ish ppd) when upping the core/memory speeds. I'll double check my work just to make sure
Go to the advanced tab and check the box that says "Do NOT lock cores to specific CPU". At this time, the non-cpu locking feature is broken, although when they fix it, you will already have it setup.
1) *looks at the website header* "Overclockers Forums" hmm...yes, you *must*3 questions.
1. why OC the shaders? do you HAVE to do it? or is this an optional step?
2. can you run this on more than 2 cards? maybe 3 or 4?
3. can you use 2 (or more) different cards?
Not sure, all my version have had it, I only recently got into the clientYeah thats what I was thinking maybe you have a new client. I didn't bother to download it because I already had one.
I'll have to back and see if I can update mine. Does this new one fix anything?
Also I never needed an extra monitor and didn't have to reboot.
Again terrific job... instant 9k+ rig.Top 20 here I come!(Yeah sure dream on )
3 questions.
Not sure if it fixes anything as I've just run this one client.
Here, let me draw a picture.I am using a EVGA 8800GT 512mb dual slot
with a Gigabyte 8800Gt 256MB
My question is how do tell which GPU is folding which client?
