Need a little advise. I bought an AGP 6600GT just to get me by for a while longer. My current 2.8 O/C’d very nicely from 3.1 to ~3.4 with that new thermalright XP-120 heat pipe. Those things are magic. But my system is still just not “Uber” enough to be able to really take advantage of a 6800 and I really don’t want to throw any more $$s at AGP. But I’ve run into a problem . . .
Question 1:
The graphics are fraggin’ badly. All the weird symptoms of an overloaded PS. My Enermax EG365P may have hit its limit with that 6600GT, but my voltages all stay perfect. I log them with MBM during a frag’ing session with MSFS or LOMAC, but the symptom is still very suspicious! I guess question # 1 would be “If voltages remain within limits, is this a positive indication that the PS is still fully capable of providing full current to the load.” Or the same question asked the opposite way: “Will a voltage fall-off always occur as the ‘observable’ electrical indication that a PS is being overloaded?” As far as I know, there is no way to directly measure amps without add-on equipment: So, if dropping voltage is not a way to see this, is there some other way to confirm that a power supply is NOT providing all the current the load is asking for?”
Following up with a possible explanation for a lack of falling voltage level: “Is a PS designed to throttle back amperage to so that it can maintain a rated voltage level or perform the function of a softly landed circuit breaker?” But then to continue the discussion: “Wouldn’t the PS ‘spend’ at least some voltage to maintain amps for at least a little bit?” I’m really looking for a voltage drop as an indirect indication that amperage is NOT being maintained, but not seeing it. My little ‘ol power supply’s volts are staying solid as a rock
Question 2:
So what do you think? Well how about this. Setting my bad case of technoiditis aside for a moment, I can see the writing on the wall. In a year or so, I want that FX-6X, SLI’s 7800 rig and it’s not going to hurt me to get this system’s PS now. But in the mean time, I will be using it with a system that is more suited to a mono-rail system and . . . .
This dual/ triple/ quad rail thing has me baffled. What are they doing here? Well, I have an idea, but how can I appropriately use it with my current system. Are the various 12v busses simply hard wired to various plugs? For instance, in a dual 12v buss PS, is one of the 12v busses hardwired to the main and drive connectors and the other to the “SLI Qualified” PCI-E connectors? . . . or are there sensing circuits in the PS that switch the load on the basis of a connector it sees plugged in. (My concern is that this might be a little too much wishful thinking.) Will I need to get a PCI-E to Molex adapter to even utilize that second/third / even forth buss (Jeeze, it’s getting to be like the # of blades in the latest razor!) . . . if I don’t have a whole box full of PCI-E Vcards?
T’was recommended here by a real knowledgeable guy. Thought ya’ll might have some fun with this . . . .Thanks in advance.
Question 1:
Question 2:
