multi system water chiller pics
sonicdrive
ohio
hey all like i promised here are the pics for the multi system water chiller pics
the systems
sonicdrive
sonicdrive
ohio
this is the back flow txv for the system
sonicdrive
sonicdrive
ohio
here are the water pipes with the cooling coils
sonicdrive
sonicdrive
ohio
the control station i got off of a old boiler set up and ac set up from friend that was doing a job replaceing them
sonicdrive
sonicdrive
ohio
the water pipe 4 inch round
sonicdrive
sonicdrive
ohio
the reserve tank with no insulation on it
sonicdrive
sonicdrive
ohio
inside the box and the fan to cool the system and evap
sonicdrive
sonicdrive
ohio
3 systems the water will flow in a S from the water pipe to cool down in a scale there is 20 ft of copper cooling line in each water pipe soo there should be enough if my math is working out LOL got to love backyard Engineers
CreePinG_DeatH
What are the specs on the compressor you are using? What refrigerant are you going to use? Expected temps of the water? How hard did you plan to push your rigs? And finally, what did you plan on cooling....just the cpu? Or like cpu, gpu, ram etc....
sonicdrive
sonicdrive
ohio
the details will be posted 0nce it is assembled and running i dont want to use any specs with out knowing with out a doubt in my mind that it right the other questions i plan on cooling the cpu gpu no ram i dont want to mess with it the temps i plan on getting is 0 f with a alcohal mix under no load and with a load i can only hope for temps around it +- 8 Deg F 404 is the frig gas being used pump i cant tell you right now because it isnt with me it came out of 50K btu ac unit
