Yes a 1600XP. I tried to run the memory at 125mhz+HCLK+PCICLK, and I got higher memory score In
Sisioft Sandra with that setting.The Cpu at 125mhz x12.5 mult.
=1566mhz.The Cpu can do over 1700 mhz, so it would be nice with higher multipler.
You mean 100FSB + 25MHz & running the DRAM CLOCK at HCLK+PCICLK right Well that's a 25MHz overclock on FSB that affects your PCI & AGP but your CPU to Northbridge is still below par I think. Maybe the 133 setting were not optimized. Wanna give it another try? If so kindly list down your SOFT MENU III & ADVANCED CHIPSET FEATURES exactly how you see them in the BIOS. Your system specs would also be handy
Soft menu III setup
Cpu operation speed User define
Multipler factor 12.5
Cpu FSD/PCI clock 110/36Mhz
Cpu FSB Plus 15
Speed error hold Disabeld
Cpu Power supply User define
Core voltage 1.425(Voltmod actual 1.90v)
I/O Voltage 3.80
Fast Cpu command Fast
Output Drive Control Auto
Enhance chip performance Enabled
Force 4way Interleave Enabled
Enable DRAM 4K-page mode Enabled
DRAM clock HCLK+PCICLK
Advanced chipset feauters
Dram timing Normal
Dram bank interleave 4 way
Delay dram read latch Auto
MD Driving strength HI
SDRAM cycle lenght 2
the rest of the settins is untouched
ABIT KT7A-Raid
AMD 1600XP
256mb/pc 166
ATI All in wonder 128
Sisoft sandra shows:
Front side bus:2 x125Mhz
Logical/chipset Memory Banks speed: 166Mhz
Agp bus: 84Mhz
Pci bus: 42Mhz
Or would i benefit more if I set the FSB at 150Mhz Multipliert
to 11.5=1725Mhz, if it is not possible with higher multiplier than
12.5?
Soft menu III setup
Multipler factor
Cpu FSD/PCI clock.............133/33Mhz
Cpu FSB Plus......................0
DRAM clock.........................HCLK
Dram timing.......................Turbo
Which BIOS are you running? There was a change in the Dram Timing Values;
SETTINGS.....tRAS.....tRP.....tRCD
BIOS version WZ & later
8/10ns.....6.....3.....3
NORMAL...6.....3.....3
MEDIUM....6.....3.....2
FAST.........6.....2.....3
TURBO......6.....2.....2
BIOS version TL until WW
NORMAL...5.....2.....3
MEDIUM....6.....3.....3
FAST..........6.....2.....3
TURBO.......6.....3.....2
