Multiplier problems with a7a266
Valin
For some reason i cant get the multipliers to change in the bios, I have connected the L1's and still wont work. I also cant get the FSB past 122
A7A266
Duron 750@920
256 DDR pc2100 crucial
Nvidia geforce2 gts
Sound Blaster live!Value
WD 13gig HDD & 45gig HDD
On the motherboard connect the #10 dip switch together if there isnt one. That is if you got the older version. You can solder a piece of wire or just use a silver pen to connect the 2 dots. Then multiplier settings can be changed from the BIOS.
i have the version with all 10 switches and i still cant adjust the multiplier.
Hiya's,
I know this as maybe said before but for guys like me i thought a fresh post would be ok
Got a TB 1.2 on the A7a266, Now the Bios is underclocked to say the least lol, As you can't with any bios so far have multiplier and FSB working together in the bios/jumperless mode so i finally read n re-read a post about managing to achieve higher Multipliers
1...Goto Jumper mode (JEN 1-2)
2...Set Dip #10 (or join connects where #10 should be) to ON
3...Now set the Multiplier via Dips #6 to#9 accordingly
4...Set Dip #5 to DDR=OFF, SDR=ON
5...Power Up as normal after checking bios as she boots
6...UNPLUG PC, DO NOT GO THROUGH SHUTDOWN SEQUENCE
7...Just move JEN jumper back to 2-3 (Jumperless)
8...Boot into Bios and UP all you want
Hope i remembered it right lol, Only took me 8hrs to absorb it from a BB post (OK so i'm slow lol)
Have Fun
Happy OC'ing
Def
ps.....anyone know a volt mod yet for the A7a266 ???
lol best say 1.2 at 1.4 at 1.75v H2o cooling
I have unlocked the chip, and i am rnning bois version 1005 I still cant change the multi in the bois and I'm really lucky if the dip switches will change it and post.
