My 1st watercooled rig
rewind_rob
PA
I am waiting on the case and i could not wait so i put the system together. i need to cut the holes for the 120 fans.
anyway here is the system
i am getting 31C at idle and 36C full load..
well i have a question.. sort of.. its a P4 3.0Ghz 1gb of kingston PC4000 DDR and a asus P4C800 i cant seem to get it over 3.600GHz i messed with the voltage but i only took it to 1.6 when i did that it would reboot during 3d2001 for the stress test. anyone have any tips to get this sucker higher?? thanks :attn:
Styyn
St. Paul, MN
You should be fine bumping your vcore to 1.65 or 1.675, but after that you're entering the grey-zone for P4's. Your memory timings and GAT/PAT settings could also be a limiting factor here.
Btw, your sig is way, waaayy over the limit ;)
