Oops, 0.02v - sorry!
As for the BSOD - x00000124 = it needs more voltage (or alter DVID to -0.015v from -0.020v). That might resolve the problem. Every x00000124 I've gotten is voltage-related.
1.32 BIOS and 1.284 in CPU-Z is perfectly safe. If it'll do 44x stable at those volts you have a pretty decent chip, certainly better than mine. Good luck!
Thanks!
Focusing on the slightly higher voltage that is shown when in BIOS. Isn't 1.32V still far from damageable for the CPU, I mean, isn't Intel's own max recommended CPU voltage higher, I've read many stuff in forums but most seems to agree that it is around 1.37-1.38 (and that must be BIOS voltage because cpu-z seems more sketchy) for the i7 2600k size CPU's...
Might give the 44x a shot if I only can feel safe going from BIOS 1.320V to 1.325, 1.330 or whatever would be require for it to pass a prime95 and not BSOD after 30-60 minutes... I guess it is not something I can do with the QPI/PLL if the BSOD code complains about cpu core
42=1.345
43=1.355
44=1.360
45=1.360
46=1.360
When I ran 4.8GHz just for a quick cinebench test I was at fixed 1.35V. I have tried a lot of stuff and what I found was that whenever I had the RAM at 1600MHz I got BSOD right after I clicked blend test, downclocked to 1300 I could have it running at least a few minutes.
Right now I have it at 1066 but I will see if 1300 works as well at 43x. I don't even know the difference between RAM frequency but my stomach tells me that this is my personal priority list when it comes to RAM:
1. Amount of gigabytes!!!!!
2. Timings
3. Frequency
I've been using a Mac Pro at work since 2008 and that is 800MHz RAM, never complained about anything except that 8 GB is waaay too little for what I do.
If you have the time you could always downclock the RAM frequency to 1066 instead of 1600 and see if it runs stable with the setting krose posted photos of. I think I'd rather run 44x and RAM@1066 than 43x and RAM@1600
Also, I don't use profile RAM in BIOS because it sets the voltage high at 1.65V!! (which is what the corsair xms3 wants at 1600MHz. I also use "Standard" instead of "Turbo" in the RAM BIOS settings...
What it really comes down to is SB you can't up the BCLK = (FSB)speed so upping the ram speed will not help because you run into SB BCLK speed bottle neck.![]()
Increaisng memory speed wont help because of BCLK bottleneck on SB.What bottleneck?
http://www.xbitlabs.com/articles/memory/display/sandy-bridge-ddr3_4.html
Having applications that can use the ridiculous bandwidth is another story.![]()
