It came with my Antec 1040b case. Had it for a month now, but I only just started using it less than a week ago.
I just turned my comp off to listen to it again, can't hear it once its going even with my head against it. It actually makes a sound like a sqeeky bike brake sqeeky-hum sqeeky-hum sqeeky-hum sqeeky-hum...
if its like a camra flash charging then it is the capaciters charging up other wise if its much lower like 50 - 60 hz then it will be a bit of mains humm this may be a lose screw or a capaciter thats dieing my amp does this if u got a big amp does it sond like this.
i recon its just the caps i would not worry
yea i have a 500 wat psu and my thing makes a noise like that its hard to explain its sorta like a ring in ur ear buggs me sometimes but that smell is a new power supply smell give it 3 weeks or so itll go away and that noise is from larg power supplys
