Ah, here we go...... they are definitely a bad batch, or maybe a common factor in mem, cooling, or motherboard?
I've had 3 different cards and here's the results (reason I had 3 was because of BSODS that ended up being my Power Supply):
First card: 325/720 with minimal artifacts
Second card: 315/710 with minimal artifacts
Third and current card: 320/715 no artifacts, but run it at 300/700 for 24/7 use.
These 3 spanned from a 1.5 month time frame all from the same distributor. The company is Leadertech. Now I'm not sure if everyone can order from them, but they are our supplyer for my work. So of course I can get bulk discounts etc, and discounts on a single.
I've had 3 cards and all 3 performed better than "advertised".
Also, use Rivatuner to find out what core revision is being used, all 3 of mine have been A3, maybe newer ones are using a different revision due to the fact of nVidia shutting down 4400 and 4600 production which could be effecting the chips they are sending out.
