I finally decided to try the "pencil mod" from VR-ZONE.com) ...Im using the stock HSF... Im using a Digital Multitester to measure Resistance and Voltage.
*default voltage: 1.405 @ 416 ohms
idle temp=55C
with load =75-85C
max stable CORE: 530
**after the mod: 1.64 @ 357 ohms
idle temp=65C
with load=95-105C
max stable core: 600 (so far).
Now here's my question: is 1.64 volts too high and dangerous? Should I lower it or go for more? I would like to stick to aircooling as much as possible?
After determining the "maximum safe value" (resistance), Im gonna replace the pencil mod with a Cermet Potentiometer.
Then after doing the CORE MOD, Im gonna proceed to the VMEMORY MOD, Then to the OVERCURRENT MOD.
Again I need advise regarding the voltage: Any inputs?
idle temp=55C
with load =75-85C
idle temp=65C
with load=95-105C
