my bios settings.... are they okay?
kfc
im [email protected]
windows runs fine at around 35-39c idle. but prime95 locks up fast.
these are my settings...
external clock - 200mhz
multiplier - 11x
agp freq - 66mhz
cpu fsd/dram - spd
cpu interface - enabled
cpu core - 1.75
I have even tried to but the core to 1.775
set ram to cas 2.5
disable cpu interface
but nothing seems to work right in prime95 :?
are the above settings okay to use? if not what.
any ideas on where to go next?
tnx
with prime95 i get this error
[Fri May 10 16:59:55 2002]
FATAL ERROR: Rounding was 0.4999365807, expected less than 0.4
Hardware failure detected, consult stress.txt file.
at 2ghz and 2.2ghz with diffrent bios settings. I duno wtf is up :/
check my sig. for a good 'safe' OC on the 2500 Barton
RUNS PRIME ALL NIGHT/DAY
