Shroomer said:I hope you do tap all the way through. I have been planning a very simplified version of the block you're making for quite some time. Simply 2 - 1/4" holes drilled 1/8" appart, then tapped all the way through and plugged. Then just the barbs on top.
I WANT the flow restriction as it adds to the velocity of the water and the turbulance created. The idea for me is to have the water enter and exit in a very short time. I could not use mine with a pelt, though. You could easily with your design.
You will probably be done with yours before I get a chance to start mine. Perhaps try NOT tapping at first and just use teflon to seal the plugs. test it, then go back and tp the sucker. It'd be a good test. When I do get around to making mine I will be making 2 seperate blocks to compare.
