Sounds like the luck i would have. My best OC on my last set of ram was dropping the CL from 32 too 30.4800 was the best I could do
You say wasted, but that's exactly where you need the speed as most files are tiny and random (we talked about 4K r/w in one of your threads).My Crucial T705 is a speed demon but alot of that speed gets wasted on random reads and writes but it still beats most drives.
I'm in your same position here. I mentioned it before that I partition my fast OS drive. It's 1TB with, as of today, ~360GB carved out for the OS. This is a bloated OS for me, and is about 170GB total (so after over a year on this OS I have ~190GB free). The leaves ~570GB of PCIe 5.0 for games, while the rest sit in a 2TB PCIe 4.0 drive.Hopefully Amazon credits my account quickly as i dont want games on this 705 and just use it for windows and programs.
Is it? You have bigger drives than me... I'm running 1TB and 2TB.Thats a large SSD your using. My 705 is only 2TB but the T500 that just died is 4TB and it fills up fast with such large games.
ImI said you likely wouldn't notice the difference... and at the time, likely could have been spent on other things. Understand that half of the system I have is from reviews... most isn't my money (but time).Didnt you get on me saying i was wasting money with a Gen5 drive?
Lol that is why you are wiping out windows. BCLK tuning.
I just put a negative 25 on all cores in the curve optimizer i think its called.I suspect you are trying to overclock your cpu using old school methods...not going to work out well. Counter intuitive, but those negative values will net you higher frequencies as well as cooler temps overall.
yes i see it but ive done nothing to increase the Bus, Its just bugged and you can see that looking at my last reported speeds.
How the heck you score so high when we have the same clock speeds?It does not vary for me...try DLing the latest version and see if it acts the same.
