my build....for the near future
Dino-Man
AJ Arizona
Heres what i plan to build by may or so and the psu not sure if it will work with my mobo below so if you could give me your advice that would be great.
http://www.newegg.com/Product/Produc...82E16817153039
^power supply
http://www.newegg.com/Product/Produc...82E16819103194
^Cpu
http://www.newegg.com/Product/Produc...82E16814130328
^GPU (not sure if i should get this one becuz i do plan to do sli) Either the 8800 gt/s not shure give me your thoughts please.
http://www.newegg.com/Product/Produc...82E16813131013
^mobo
Right now i got a gig of kingston ram
80 gig harddrive(very sad i no....)
acer 22" bought 2 days ago
I do plan on getting more ram maybe 2 more gigs
The forum has shortened your links and they are now dead. Please edit your post with the links again :)
From the thread in the Nvidia forum.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153039
^power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103194
^Cpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130328
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131013
^mobo
I doubt the 9600 wont be able to handle crysis at high like you want it to. I have the 8800 gts 512, which is faster than the card you have selected, and it barely keeps up at 1920x1200.
o so
how bout 2 9600's?
how would that do?
or
two 8800gts
both are 512
other than that hows the other stuff
My 22" Acer only goes to 1680x1050 and the 9600GT runs Crysis on High just fine. I have only played the demo but I think it gets around 30fps.
so thats just one 9600gt right?
by may prices will be way down right so thad be a good time to buy all the stuff Right? lol
By may, things will most likely have significantly dropped in price. If you dont plan on buying something by then, dont go ahead and buy the rest, because you'll be paying today's prices, and wont be using it. By the time you get around to using it, you'll have paid way to much for an outdated product.
All I suggest is on things like the HD, PSU, HSF, and case go ahead and buy it early if there are good deals. A lot of people wait to order it all at once buy could save a ton by shopping for it for 3 months.
