- Mar 4, 2008
- AJ Arizona
Heres what i plan to build by may or so and the psu not sure if it will work with my mobo below so if you could give me your advice that would be great.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153039
^power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103194
^Cpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130328
^GPU (not sure if i should get this one becuz i do plan to do sli) Either the 8800 gt/s not shure give me your thoughts please.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131013
^mobo
^power supply
^Cpu
^mobo
