When I get the sound doing loops on a blank screen it is usually the Driver, The Gpu is Oced too far or Something is wrong with the Gpu.
Now just so we are all on the same page you have done the following correct?
Did a clean install of a new gpu driver?
Ran Memtest?
Running the Cpu at stock clock speeds?
Have you checked the Pci-E power connections, I know it may be silly but sometimes it's the little things we miss. Make sure they a properly seated.
Do you have another Gpu you can use to test the system with or another system you can swap the 970 into?
Memtest you should run at least 4-5 passes to see if there is an issue.
Having you're Gpu tested in another Pc is a good idea.
So if its the os i should do a clean install again? Since after the clean install i did it said that you can't go back to Win7 after it was done
