- Jun 22, 2013
As seen in picture, I have a Silverstone PS07 with the hard drive cage removed. The CPU is a 3570k on an Asus P8Z77-M Pro. The CPU cooler is an Enermax TB-60, supposedly one of the newer and better top-down CPU coolers on the market. I opted for a top-down because I wanted it to cool my motherboard.
The CPU runs pretty hot with this setup. With an ambient temp of around 27C, it hits low 70's at a mere 4.0ghz OC @ 1.21v and would go to mid 80's with 4.2ghz @ 1.26v. As you can see, the fit of the cooler is pretty tight with the case and the video card, so I guess the air flow isn't optimal. But here's the kicker: after experimenting with various fans setup, the conclusion is that fans make virtually no difference in improving my temperature.
I originally had an exhaust fan (CM blademaster) right next to the cooler. No temperature improvement at any speed from 600rpm all the way to 1800rpm, even though I could feel hot air going out. As a matter of fact, higher rpm seemed to result in higher temp. So I removed the exhaust fan, no increase or decrease in temp at all. So I'm currently running with intake only, no exhaust other than the PSU fan facing inside.
Next I played with various settings with the stock fan on the CPU cooler, which is an Enermax 120mm PWM fan 800-1800rpm. Again, having it at full blast or a mere 1200rpm make no difference in CPU temperature. So I just removed the stock fan and sticked on a Gentle Typhoon AP-14 1450rpm. Much quieter and no effect on temperature.
Finally I upgraded both front intake fans from some super week 900rpm Silverstone's to GT AP-14's s as well. But as you might have guessed, zero difference.
I re-installed the CPU cooler twice (using MX-4) carefully to make sure that it's not a bad installation.
What do you think is the biggest problem in my setup? The cramped space around the cooler or the air path? I find it hard to believe how fans can be so useless in my case. This is probably the biggest waste of 3 Gentle Typhoons on earth.
Edit/Update: After taking the advice from the wonderful posters, especially doyll, I flipped the CPU fan over to mount it as an exhaust, and temperatures dropped across the board. Thank you!!
