Hmm. Never heard that one before. Do you have any links to this tidbit you mentioned??? I would bet its the board limiting it in this case... G41 chipset is not a noted good overclocking chipset.Normal. My e5200 won't do over 340 without a lot of vcore.
E5xxx cpus are core2s with a defect in the FSB bits that prevents the use of normal FSB.
I have yet to see an e5xxx that goes over 350fsb or so, most eat it around 320-340 unless you crank the volts way up.
On that G31?
On that G31?
