- Aug 5, 2002
So over the past week I've been working with the Corsair H115i Pro. It hasn't been any smooth sailing so far. Can actually see some images and the nice results I was getting over in the case section when I was piecing togeather my system
Fractal Define R6... in Gunmetal as well over at Corsair's website in the cooling section to try to get help, which sadly never came Install Issue - H115i Pro - Not enough clamping force?. Was going to post in here to see if anyone had idea's last night before I contemplated RMA process but then I did something
Originally starting this up I got results out of the park. 4.5Ghz with 1.275V = Thermal Throttle and core temps all over the board. Mostly Core #1 spiking to 100C constantly, yet other cores almost 40C difference! Eventually after many remounts and tries I loooked into figuring out the problem at a non-thermal throttle state and down clocked her to 3.2Ghz with 1.1V (probably waaay overkill). Anyways Core #1 got to top out around 80C and the remainders where all over the board at 60, 45, 55 etc. I took the whole setup out of the case because at this point, I'm ready to drop in my heatsink beccause I have no clue what else to do.
So dropped my mounting bracket back on there for my Ultra 120... figured hmm, why not try this out with that bracket. BINGO! Eventually after a few different remounts Core 0 and 1 was reading nearly the same, and Core 2 and 3 was reading nearly the same. I was getting closer and dropped temps more. Then thinking I saw a few posts about the block just pushing to much on the socket it was bending the board (really I doubt it was that much to bend the metal plate on the back) but looked at the backplate and forgot I still had on some thicker washers I purchased recently. Dropped in the old washers I had on it from my heatsink and retightened down everything and finally... we have contact! Sadly the cheap POS backplate and mounting bolts never gave it a chance to get a decent contact on the board. While maybe its because my board is a few years older, and newer boards are maybe stiffer since it is a new release and the mounting system for the older revision of the blocks is slightly different (different screws, slightly shorter stand offs). Not sure why they would modify it but what ever case my old Ultra 120 Backplate will live on, and make a really easy switch if I ever need to put the heatsink on since its just 4 screw caps, remove block, place bracket, heatsink and heatsink holder. No need to take off the backplate
So while I wasn't expecting higher end heatsink performance out of this, actually shocked that I am. From the last IntelBurnTest I did with my stock heatsink I'm down in temp, from 79-82C to 66-68C (30min run) at the same speeds/settings. I know at least on the CPU wasn't going to expect a world of difference but wow I'm amazed. Think I might crank up the CPU some now since daily use/playing I doubt I'll be hitting those high temps, and that is with everything running in a balanced mode. Fans for the rad are running off CPU temp so flux between 600rpm (idle) and 800rpm (highest I saw) which is based off either CPU or water temp with the default settings, not sure. The other case fans are in balanced as well, but run a solid 750rpm. Fan location, 2x 140mm on rad for intake, 1x 140mm on rear exhaust, 3x 120mm on top of case exhausting out.
Here is some pics from the last result. First is idle temps and second is load temps after 30min.
