- Sep 5, 2005
- Anchorage, Alaska
I have attemped my first overclock.
Even the slightest tweak becomes unstable in 3DMark & boots me to desktop.
My System:
Asus P4PB-400
P4-2.40 Northwood
1024 333MHz DDR
Radeon 9800XT-256Mb
CPU Fan: Zalman CNPS7000B-AlCu LED
Northbridge Fan: CoolerMaster Blue Ice
GPU Fan: Zalman VF700-Cu LED
Case: Tsunami Dream
1-120mm Front Fan
1-120mm Rear Fan
1-90mm Side Fan
Ambiant Temp: 70 F
Idle Temp: 36 C/96.8 F
Load Temp: 41 C/104.0 F
I first tried a software overclock from my chip maker VIA, called Jetstream.
The stock setting was:
FSB-133.31
Vcore-1.52v
36 C/96.8 F
Worked fine in 3DMark.
I hit the "Turbo" button and got:
FSB-140.00
Vcore-1.775v
Booted me to desktop 1 minute into 3DMark.
With the software overclock, it's stable at:
FSB-135.00
Vcore-1.500v
3DMark runs fine.
So I decided to do my overclocking in the Bios.
Anything I changed in Bios, resulted in 1 0f 2 outcomes:
1. Would not boot
2. Booted me to desktop 1 minute into 3DMark.
Ofcoarse, even after reading a ton of overclocking information, thanks to you guys, I STILL don't get how to do it.
My other computer has multipliers I can adjust, but this one does not.
Here is my Bios for overclocking:
DRAM Clock:....................[166] (choices-133MHz, 166MHz, 200MHz)
DRAM Timing:...................[Manual] (choices-Manual, By SPD)
SDRAM Cas Latency:.........[2.5] (choices-2, 2.5, 3, 1.5)
Bank Interleave:...............[Disabled] (choices-2 Bank, 4 Bank)
Precharge to Active(Trp):..[3T] (choices-2T, 3T)
Active to Precharge(Tras):[7T] (choices-6T, 7T)
Active to CMD(Tred):........[3T] (choices-2T, 3T)
DRAM Command Rate:.......[1T Command] (choices-1Tcommand, 2Tcommand)
DRAM BurstLen:...............[8] (choices-4, 8)
AGP Voltage:...................[1.5v] (choices-1.5v, 1.6v, 1.7v, 1.8v)
Current CPU Voltage:........[1.525] <grayed out, no choices.
CPU Vcore Select:............[Default] (choices- 1.100v thru 1.850v)
DRAM Voltage:................ [Default] (choices-2.8v, 2.7v, 2.6v)
CPU Clock:......................[133] (choices- Min.=133, Max=200, Key In A DEC Number________)
How would YOU clock this?
What's the step by step?
My System:
Asus P4PB-400
P4-2.40 Northwood
1024 333MHz DDR
Radeon 9800XT-256Mb
Case: Tsunami Dream
1-120mm Front Fan
1-120mm Rear Fan
1-90mm Side Fan
Ambiant Temp: 70 F
FSB-133.31
Vcore-1.52v
36 C/96.8 F
FSB-140.00
Vcore-1.775v
FSB-135.00
Vcore-1.500v
3DMark runs fine.
1. Would not boot
