MY First hardware mod (GeForce2 MX200)
Rezman5
Philidelphia, PA USA
The cooling on this thing...well...sucked! When I first took of the CPU, there so NO thermal paste between the tiny little HSF and the GPU. I modded an old P// HSF to fit on this card, and chopped up an old P/ for the RAM sinks...which match the pretty gold of the card too!
eli
i noticed the listerine tabs there.. gotta keep the breath fresh while modding!
Breadfan
Inactive Moderator
Northern VA
Awesome job!
I know my Gigabyte GF2mx came with only passive cooling...and yup, not much in the way of thermal paste...took care of that one night, but didn't do the ramsinks...maybe some other time.
Mike
funnyperson1
Senior Member
yep love them listerine tabs...nice job on the mod...be sure to show us some benchies:)
Starfoxer
World's Biggest E-Thug
USA
looks good :p
might wanna clean the dust off on the fan. it should be
perdy old too, maybe loob it? DW-40 works good.
Rezman5
Rezman5
Those tabs are addictive and powerful! Plastic death as I call them :D I broke out the compressed air, and one good shot took out all the dust! The benchies pretty much such, the card is a no name and only overclocks to 180/180 from 175/165 :( Oh well...next up is my GeForce 3 Ti200 when it comes back from RMA. Gotta put a cryorb on it and some better Ram sinks
Garfield
New Jersey
So what you did was just take off the fan on the GPU and put some Artic Silver in? Maybe I should do this. Not hard?
funnyperson1
Senior Member
first you either have to get the card very very cold (freezer) or very hot (gaming;) ) then pry the heatsink off...i prefer using my hands and wiggling it off...after that is done you use Artic Alumina Epoxy as it is non-conductive and wont kill your graphics card to glue on the new heatsink....
Rezman5
Rezman5
Well, mine was held in with those spring clamp type things, so all I needed was plyers. There is no atric silver in there...I made myself a new heatsink from an old Pentium HSF, and it is stuck on there with artic alumnum epoxy. I also made the RAM sinks. Man are hack saws great!!!
NASsoccer
On a string I was held Senior
i live
great job on the mod, how much of a temp drop do you think you got and how much farther can you puch it?
Garfield
New Jersey
I don't seem to be having OCing problems with my video card. Take a look at my sig. That's my card and that's my temp. When do you usually start worrying about this?
Rezman5
Rezman5
I dont think I have a way of getting the temps from my vid card. I didn't get much of an improvement, like 5 Mhz GPU and 15 Mhz RAM...becuase it is a cheap card and doesn't OC well. I can't wait till my GeForce 3 Ti200 comes back from the RMA...I am going to put a crystal orb on it and new RAM sinks
NASsoccer
i live
i just put a crystal orb on my gf3 and in the process i slipped one of the flat sensors that came with my DD5 under it. That is the only way i monitor my temps.
rUfUnKy
Ma.
Looks to me the fan is sucking not blowing on the H/S ..Try flipping it around...
rUfUnKy
Ma.
Rezman5 said:
No, its blowing on the HSF...it is just a really old fan!
LOL ..ok just making sure... The lable usually faces in the direction of the air flow..now that I look at the blades the curve is facing the right way..:eek: P.S. Nice job :)
