- Jun 15, 2004
- Thread Starter
- #101
djs488 said:okay gotcha . do they actually make replacement pins, or are these like adlib.
Yeah, you can buy the pins from most places that sell the PSU changeover kits. I got mine from www.frozencpu.com
They make tools to make removal of the various pins easier, but I decided $10 to $20 was way too much for cheapo little tools and built my own. These are for removing the 6-pin connector and the ATX/P4 Connector. I made them at work tonight. I got lucky, and they actually work great
Thanks. I explained the reason for FX Fusion in one of my previous posts. The X was designed like that to try to stay with the design on the case. I think it turned out rather well too. I am going to make some fan grills using the same X. I will probably engrave the FX Fusion text around the outer ring of the grilles too.walkitiki said:Just wanted to tell you how much I like and appreciate what you're doing. I think it's great how you incorperated the, in my opinion ugly, "X" motif on the case and put it into your logo and turned it into a piece of art. Great work, love everything about it!
