well after running my system for like 15 mins with the
[email protected] client going these are what my temps are now...
Sensor 1 = 45C
Sensor 2 = 35C
Sensor 3 = 72C
so basically my WinBond3 sensor went up 2 degrees celsius after running
[email protected] which makes me assume that that is my CPU that is WinBond3 and that is running so hot...again, lemme state that this is a budget system...the case I have (which cost me $7) isn't bad except for 1 thing...the PSU is mounted above the CPU, leading for all kinds of work when doing stuff underneath it, however because of this positioning, would a better HSF really make a difference?
~jeff~
edit: its been running stable for like 3 or 4 days now...no BSOD..no registry problems...no crashes..no lock-ups...only thing is sometimes I dont get sound from some things im doing around the winxp desktop...but im guessing thats more because of the SB pci 16 sound card than anything else...BTW: pci clock is 31 and agp is 62...this board has weird multipliers for 124 mhz....i wonder what would happen if i bumped it up to 133mhz....
edit2: just checked the temp of the cpu in the bios and it was reading right around 40C...which means that Sensor1(WinBond1) is prolly the CPU temp since the temp was taken immediately after rebooting...im guessing the temp of 71C is coming from the northbridge...because while my comp is on the HS over the CPU is warm but not hot...however I could fry an egg on the HS above the northbridge...any ideas how to cool the northbridge anymore? I've already applied thermal epoxy..so I dont think I can replace that HS now... =(
