My first PC build questions
Jdubbs92
Okay, this is something I've wanted to do for a VERY long time. I picked out all of the parts and will post them. I want to know if they are all okay to work with each other, if I'm finished looking, and ready to order?
If something isn't right I'd love advice on what's missing or how to fix it.
here are the links!
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&Tpk=i7 2600k
GPU: Visiontek 900353 Radeon HD 6970 Video Card, or Radeon HD 7950 Video Card (most likely choice 1)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7101566&CatId=3669
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1766293&CatId=7387
Hard Drive: Western Digital Caviar Green WD20EARX 2TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (possibly adding an SSD in the future)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136891
Disc Drive: Blu Ray
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106369
RAM: Kingston HyperX 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104169
Motherboard: ASUS P8Z68 DELUXE/GEN3 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131791
PSU: CORSAIR Professional Series HX850
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
Case: COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
There is all is! Any replies would be amazing!
Thank you!
Also I have some other fan for my HDD, CPU, and GPU on the list. I have these, because I do intense gaming, and some heavy editing/recording and stuff (thus the amount of ram)
Edit: Also the OS is windows 7 64bit!
You're on a roll. What's the budget? If you can work an SSD into the mix for your OS and primary apps you'd enjoy load times. Otherwise, looking good. Might want to look at the forums regarding video cards, lots of good input for thought, although you aren't slacking with what you've picked out.
Well the final total with the 6970 comes tooo $1811.50 plus shipping and handling for parts. If I go with the 7950 it will be around $1897 plus the shipping and handling. Surprisingly CHEAPER than I though it would be ha ha. Of course those totals are with the exra heatsink and fans I have lined up. Cheaper if I would just go with the in the box fans.
Technically I HAVE an SSD picked out. I've just never split and OS and regular files between two hard drives. Really I don't have a clue how ha ha. I would love to put my OS and some games on the SSD and then have my editing stuff and junk all on the HDD?
What's the amount of money that you would prefer to spend?
What are you going to do with it (be specific)? If gaming, what games? If other, what software?
Do you prefer it to be small? Quiet? Live somewhere where electricity is ridiculously expensive?
Any other preferences?
Ya.. If it's a gaming rig only. Get a 2500K, stick to 8GB of RAM. and Definitely get an SSD. I cannot justify a brand new build of this type of budget without an SSD!! ><
