Hello all. This is my new system but i need alot of advise. Ive posted pictures from the first configuration i made with the Rad inside the case and Glycol base coolant. The other is the system but with the Rad outside at the top and using Methanol - Distilled Water as coolant. I thougth this one was going to be better but the temp has risen from 37C ( Glycol ) to 55C ( Methanol - DW ). I may think that the problem is on the rad since it had better cooling in the first option with the 2 case fan outside, but then i thougth that the heat from the case was raising the temp and i took it outside.
Pelase post any suggestion on what to change o add to the system to get the best cooling.
*Also not that i havent done any OC to the system yet!!!
