Hi, some of you may or may not remember, but I first visited here a few months back requesting help about my first water cooling set up. Fortunately for me, some of you guys were very very helpful and answered a lot of my questions and help me figure things out.
Today I just want to make a post with an update and get a double check on my temps with you guys and take this opportunity to say thank you to those that helped.
Rig Specs:
i5 2500k @ 4.0GHZ 1.23v
Asrock p67 Extreme 4
8GB G.Skill Ripjaw 1600MHZ DDR 3
Nvidia GTX 670 OC
512GB Samsung 840 Pro
Water cooling specs:
EK Supremacy CPU Waterblock Clean CSQ Acetal
Alphacool NexXxoS Monsta 360
EK-D5 X-RES 140 CSQ Acetal
Swiftech MCP655 Pump
1/2" OD tubings
Room ambient temp is about 25 - 27C
pump setting on 4, 3 x XSPC Xinruilian 1650 RPM fans running at 1140 - 1170 RPM roughly, using Shin Etsu x23-7783D
Computer idle temp according to coretemp is 28C lowest core, 37C highest core
Did a 10 run test with IBT set to very stressful and 4 core temps ranged from 40 - 49 Max.
How are the temps looking guys?
Rig Specs:
Nvidia GTX 670 OC
1/2" OD tubings
