Hi this is my first attempt and would like some help from the community much appreciated
these are the parts I'm planning on using and need some help on my tubing and clamps/compression etc... sizes.
Phobya O-ring (G1/4 Inch) UV-Reactive White (10)
Claw Clamps - Lamptron
FrozenQ Liquid Fusion Dual Bay Reservoir - Gloss White Helix
Swiftech Dual Extreme Duty Small Form Factor 12 VDC Industrial PWM Pump - White (MCP35X2-WT)
Swiftech Apogee HD High Performance 4-Port CPU Waterblock - White -
Swiftech MCR320-XP eXtreme Performance Triple 120mm Slim Radiator - (MCR320-XP)
My Case is a CM Storm Stryker and I want to use UV white reactive tubing
That is most of what I want to use. would like to know if the pump fits with the reservoir. thank you for your help.
