- Sep 1, 2011
- Chicago
I just built a new rig, I7 2600k, sabertooth P67 with thermal armor (looks solid ) and 8 gigs dual channel ram, I want 16 gigs, and was wondering what you guys recommend , G.SKILL ? Either way I will be going with 4, 4GB sticks...
Anyways.. I was playing around in BIOS (which I upgraded to the latest 1801, 1805 is still beta) and I just OC'd my 2600K. But look how cool things are? 38C ? WTF? And I am on the stock heatsink. I built an i7-950 comp a while ago and used the V10 heatsink and it was still hot, this thing has the smallest heatsink, and I am running at 4.5ghz and it is at 38C ?!!??!
Here is a link to coretemp and cpu-z when stock:
http://lawlington.comli.com/ihost/images/frupert/mypcnotoverclocked.jpg
NOW....
Here is my CPU-Z pic after upping the multiplier to 43 (103.02 x 43):
Link--> http://lawlington.comli.com/ihost/images/frupert/cpuzwow.jpg
So is this processor that godly that my temps, even with the stock tiny (smaller then the one that came with my i7 950, and that was wayyy to small for it and was practically overheating, yet is this processor just a whole new animal??
Also, Coretemp always reads at 4.4GHZ while cpu-z will be at 1.6ghz and once I start doing something (encoding, or anything heavy) then it jumps up to 4.4.. is that normal? check out this when I right click-cpu-z, am I only OC'ing one core? sometimes it shows core 2 and 3 (3 & 4) at 4.4 while the others are at 1.6 or is that just a glitch... here is the pic:
http://lawlington.comli.com/ihost/images/frupert/whycore4.jpg
Thanks for the help. I'm looking for water cooling and corsair has this 70$ all-enclosed never-refil kit, for 70 bucks? (link below) could it really be that much better? The v10 heatsync (massive air-cooled beast) on my old system was like 130$ .What do you guys suggest for the best heatsink so I can push this and really not worry. (but at 38C ... this is redic,).
Will this be the best ? http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015&Tpk=corsair h60
Or should I go with the MONSTER V10 (I have a full tower case with tons of room): http://www.coolermaster-usa.com/product.php?product_id=2880 , or is water cooling always better? I don't want something I have to refill so would that corsair water cooler blow away any air-cooled dealio ?
Here is how it is under load:
Here is how it is at idle:
yet CoreTemp will read 4.4ghz the WHOLE time, even when cpu-z says 1.6... so which one is correct.. ? any different program to recommend? (windows 7 64bit)
Also, before I OC'd it (just clicked two things in the sick EFI GUI bios, it would chill around 1.6ghz then under load run up to 3.6-3.8ghz so I guess the processor is smart and just speeds up when needs too? is that HyperThreading ?
So is it safe to have it the way it is? or could I be frying my chip slowly w/o realizing it? It seems like I could go to 5.5ghz right now... just by upping the multiplier... and it has been on for hours doing all sorts of programming so it seems stable... what do you guys think, stable, or go back to default?
NOW....
