- May 23, 2001
- Asteroid B-612
I've had this idea floating around in my head for the past two years and since I have almost no electronic engineering experience the only thing left to do is ask someone as talented as Hoot.
Hopefully one of you can help me figure out how to make one...
I'm build a new LAN case that will have different lighting options and I want to make a baybus to control all of them. However, I HATE the look of regular switches and push-buttons.
What I want to try is using toggling capacitive touch switch (it feeds low amperage current through your skin like static). They're used on more expensive stereos to control eject mechanism and I'm pretty sure I know how they work but I'm not sure how I would go about making my own.
A TouchBus would be uber pimpin' in my opinion and I have yet to see an example anywhere.
Here's the Touch Switch Diagram that I want to use. I need someone to explain it to me so I can order parts and make my own.
http://www.p5taylor.btinternet.co.uk/Touch_Switch.htm
Any feedback would be appreciated,
Captain Slug
P.S. If possible, PM or email me if you can explain to me how to make that particular touch switch.
Captain Slug
