- Dec 19, 2000
Yes you can fit a good water cooling system in a micr atx case. This project is done for now. I want to add a 156 watt pelt but it will be a while.
I ended up with a push pull configuration for the 120mm fans. It was quite tricky cutting a hole and chopping up the fan to fit in the front of the case. The pulling fan simply velcrows to the back of the radiator. I like velcrow so my pump relay next to the rear fan is velcrowed on and the pump is stuck to the bottom of the case with velcrow.
