BTTB said:
I'm not sure if you know, but I figure it's worth a shot: what's the best tool to cut plexiglass? I want to mod my computer window to have 2 120 mms.
I'm not really sure what the best tool is. I used a tablesaw and it worked great but its not a very common tool. For a few extra dollars wherever you buy the plexiglass from should probably be able to cut out an exact size you need (given that you know the size ahead of time.
EDIT: OH, just realized you were talking about cutting holes. I would suggest then maybe a Jig Saw of some kind. Just go slow. The problem I had cutting the plexiglass that I had was that I would cut through it with the Jig Saw and then it would like melt back together behind the blade!
I'd say try a Jig Saw or some other kind of reciprocal saw and if that doesn't work maybe try a hole saw on a big drill or something
Ir192 said:
I really like those fan blade guards, where did you get those at?
I got most of my stuff from
www.performance-pcs.com and
www.svc.com
Performance-pcs is a Great site with great products from great seller! Never had a single problem, he even gave me a free upgrade because one product was out of stock when I placed my order
THIS or
THIS is like the one I got. I can't remember exactly where I got them from
desolateincbus said:
i have a power supply with blue uv reactive windows and sleeving but have yet to take advantage of the glowing effect from UV light. what methods of uv lighting did you use and how much?
I used only used two of those little round UV-CCFL's that you screw right on to a fan. Something similar to
THIS although thats not the one I got. If you want to go UV, I would suggest just getting a good CCFL tube rather than these cheapo fan grills because they don't really work that well. If you got one 12" or even one or two 6" CCFL and stuck it in there it would work best. I actually found that having two small lights rather than one big one is better because there are less shadowed areas so EVERY part of the wires glow
Its not super bright in daylight, but turn off the lights and OOOHHHH AAAHHHH
I definately like the UV better than any other form of lighting.
The two blue fans are regular blue LED's and they do a good job at lighting up any dark shadowed areas that the UV lights don't get.
