how is teh fit on the outer parts? I have an aluminum raidmax and I am not happy. the parts seem as if they are not sized properly cause no bending fixes it.
With my AYHJA 1.4 TBird running at 1.85v 137x12 my temps are 47C idle, 52C load. Pretty cool. The fit quality is excellent. I bought this case from a local computer store and it was a display model, not sure if that is why. The case stays quite cool with the four 80mm's mounted in the front spots, and the dual 32cfm tri-color fans on the side (all intaking) Thanks for the props.
