- Jan 8, 2002
- Boulder CO
as some of you know i recieved a previous albatron from newegg, as did a few other people, that did not perform anything like it should have. mine did 290/620 only without artifacts. i just got a new one in and it seems to be doing better allready. i just did 3dmark a few times and it is doing 300/550 stable so far. i will continue to update this post untill i finally get my max overclock
UPDATE 300/600 works
UPDATE #2: 300/630 does NOT work. it seems like the core crashes because it becomes jerky. there are no artifacts.
UPDATE #3: 290/650 works
UPDATE #4: 290/660 gives artifacts. Bumping the mem speed down to 655 changed that problem so for now it seems like 290/655 is the max stable speed i can do. i will eventually try upping the core speed mhz by mhz until i get the max stable core speed (300 does not work!).
yup folks dont order this card from newegg... the last one i had did 290/620 and this one so far only does 290/655 which is only a little bit better. my 3dmarks are around 12600 points.
i dont wanna rma this card only because of the hassle. i just wanna warn people that if they are looking to get 310/730 like they got in a bunch of review samples, dont get it from newegg, try else where.
btw this is using stock cooling but there is a 32cfm 80mm intake fan over the card. the drivers are 41.03 and the operating system is win2k sp3. maybe lapping the heatsink and putting artic silver on the core will get me higher core speed but thats another project for another day.
