MY new system start
glassknife
Anderson, Ca.
I have started a new system. Any help will be great.
p/s------Enermax EG465P-ve 431 power
Hd-------2 Maxtor Diamondmax 7200 RPM IDE ATA/133 40GB
Looking at;
MIS Kt3 mobo RAID
AMD 2000+
dvd ???
cd-rw ???
Modem???
Ugmore Baggage
Most people stopat 1800 or 1900 instead of going all the way to 2000. Prices are continually dropping and money saved is money available later if you're one of the 99.9% of people who have budgets. Compare the actual Mhz of the XPs and you won't see a significant difference. Just under 300Mhz compared to the 400Mhz difference available in Athlon models, proportionately it's even less of a variety. What I'm saying is paying triple for something only slightly better is fine if you have money to burn or investments that will actually pay for the huge expenditure.
I assume that is one of the (few) motherboards that has integrated ATA133, so I have no better suggestion.
Are you really going to watch DVDs?
Get a writer, yup. I think Plextor and Sony are good brands
Anything that doesn't say Winmodem on it, better yet go highband :)
Video card is the hardest decicion you can make. If the high end nVidia cards come down in price they are a sure bet. Otherwise Radeon 8500 owners seem to be pretty happy, but you do still see horror stories related to ATI products and almost none with nVidias.
If you plan to get lots of RAM, Win XP pro can maintain more than any other OS I know of. Do get lots of RAM, err except it's sooo expensive right now.
G
glassknife
Anderson, Ca.
new
I saw that Print shope was out on DVD and wonder if more programs will require DVD. Can hold off on that. I will take your advice on the cpu. I like the plex if I can get it with out too much money pain. Round cables, a light, zip, extra fams, a few windows, mount the power supply on the OUT side to lower temp, some paint and 3 GB of ddr memory should do it?
G
glassknife
Anderson, Ca.
http://www.colorcase.com/thunderbird.html
This is the case I have and yes there are 3 lights in the v shaped eyes,1 HD led and 2 power leds, the diamomd should be easy to light up but I don't know what device to hook it up to yet, the cd? The top comes off and both sides. Windows are planed for the sides and a top blow hole. I would like to put teath and fangs on it if I can figure it out. A tounge on the cd door may look good too.
How do you put your Signature on this page?
All help is welcomed
