I have been reluctant to post Hoot testing, but seeing that its already on someone website that sells the Gemini WB I decided to post what Hoot sent me.
Here's a sneak preview:
Pump: Eheim 1048 (158gph)
Radiator: D.D. Heater core (low pressure drop)
Tubing: 3/8" ID Silicon
Vertical lift: 4 inches (insignificant)
All Water Blocks 3/8" ID straight hose barbs
All Water blocks inlet water temperature 25C
CPU: Athlon XP1600 12.5x145 (1822 Mhz) @ 2.05Vcore = 112.5Watts
Gemini High Flow Core Temperature=41C Efficiency=.14c/w (consistent)
Gemini Low Flow Core Temperature=41C Efficiency=.14c/w (consistent)
Swiftech MCW-462u Core Temperture=43C Efficiency=.16c/w (consistent)
D.D. Maze-2 Core Temperature=45C Efficiency=.17c/w (best of three tries)
I was totally surprised by the results, especially the Danger Den Maze-2.
I was equally surprised that the Gemini Low Flow block did as well as the
High Flow block, considering the slower flow rate that the 1/4" channel
causes. (120GPH vs 158GPH)
