- Mar 5, 2004
- Bedford, Texas
well i finally got all the pieces together to go ahead and water cool my computer, well my cpu for now atleast. and i figured someone would like to see it (well probably not ) so i took lots of pics.
i am putting all the stuff in an old comp case we had lying around and it fits, but just barely.
i have the dual heatercore in the back with 4 x delta 120mm 150cfm fans on it.
it is exhausting out the back of the case, and the intake is through the old 5 1/4 bays.
the peltier/fan power supply is in the front of the case.
the coffee can ontop of the heatercore is the resivoir for my pump, it is some submersible utility pump that i found lying around the house.
i am using a maze 4 cpu block with a 170 watt peltier, the coldplate should arrive tomorrow from danger den.
i am not entirely sure how much protection i should use to prevent condensation, i am gonna get some neoprene foam and some dielectric grease to seal the socket off.
but without any further delay here are the pics.
antifreeze
case
fanspics, i got 8 of those beasts and i am using my nexus to tame them, they are really not that bad at 7 volts.
heatercore
heatercore installed
maze 4 cpu block
maze 4 cpu block with peltier
water
i will have more updates as i get more finished.
i would appreciate any feedback.
~Magick_Man~
antifreeze
case
heatercore
maze 4 cpu block
water
~Magick_Man~
