Hello Overclockers community, first post
I bought an Cooler Master Hyper 212+ last friday because I had heat problems with the Intel stock cooler, and I saw good results, I decided I'd do overclocking, to learn how to do it.
First things first, my rig:
My objective was to reach 3.5 GHz in the CPU and 1600 MHz in the RAM. Seemed good and something reachable as I saw this guide, before start I tried to read a lot more and I reached this tutorial and I decided to follow it.
My first question:
As I searched the BIOS at optimized defaults (before moving anything) I realized my RAM was running at 1066 MHz with CAS Latency of 7.0, 7, 7, 19 (I really don't know what does this numbers mean), in the G.Skill page the specs of the product are 9.0, 9, 9, 24 and 1333 MHz (PC3 1066 MHz). Why the mother board sets the defaults to lower numbers?
As far as I could understand lower CAS Latency numbers are better, but why it has two speeds?
I successfully reached 3.52 GHz in the CPU and 1600 MHz in the RAM, my settings are:
Second question:
I set Turbo Boost to "Enable" in the BIOS, I understand it adds one to the CPU multiplier and that it is activated inside the operating system, so the BIOS says my CPU is at 3.35 GHz, but in the operating system it will run at 3.52 GHz, is that correct? it will always be active in the operating system? I ask this because I have a multiboot configuration.
Third question:
Once I have find this configuration is stable, I can still play around with the multipliers and if I don't find other satisfying configuration (I worry a lot that the temperature goes over 70 ºC under stress) rollback to this configuration and nothing goes wrong?
Fourth question:
I have read that in the final stability test, you should let the test run up to 6 hours (some people say even 24 hours!), why so much? mine has been running by 3 hours now and everything is working fine so far (Prime95, default test).
I use my rig mainly for gaming and programming.
Thanks
- CPU - Intel Core i7 930 Bloomfield
- Mother Board - GA-X58A-UD3R Rev. 2, BIOS Ver: FF
- RAM - F3-10600CL9S-2GBNT x4 (total 8GB)
- GPU - EVGA nVidia GTX 680 FTW LE
- PSU - Cooler Master GX-750W
- Case - Cooler Master Storm Sniper Black Edition (with stock fans)
- CPU Heatsink - Cooler Master Hyper 212+
- Thermal Paste - Cooler Master ThermalFusion 400
- Additional fans - Cooler Master 120MM Blue @200 RPM (intake at bottom)
My first question:
- Base Clock - 160 MHz
- CPU Multiplier - x21 (with Turbo Boost becomes x22)
- VCore - 1.21875 V
- RAM Multiplier - x10
- RAM Voltage - 1.5 V
- QPI Vtt - 1.2 V
- IDLE Temps - 44 ºC, 41 ºC, 43 ºC, 38 ºC (for each core)
- Stress Temps - 66 ºC, 65 ºC, 64 ºC, 61 ºC (for each core)
Second question:
Third question:
Fourth question:
Thanks
