First of all, i am new here so i am sorry if i make a mistake in posting or etc.
anyway, my problems are that my custom built PC are restarting by itself. All the parts are new, just a month and it keep restarting. It is not overheating problem since i'll check the temp of the CPU are round 28-32'C, so technically it not an issues. i also check the windows 10 OS using my other PC and it didn't crash/ make it restart.
i did make a mistake on using AI Suite III and at the DIP, i set the voltage rating to 1250mv (1.25v) as the Stock voltage is too high 1.392v and start the auto tuned OC. the PC restarted and there is no Overclocking fail. But when it reach windows, it keep restarting and this happen also after i pressed the Clear CMOS (CLRCMOS). This is also happen when i used my USB Win10 OS installation, it also restarted. about 16-20s, it restarted and restarted until come sometime it stop and the Q-Code stop at 04/D4.
step i already did:
replace the PSU
Trying to reinstall windows but it keep restarting as soon it get to the windows installation window
Using IGPU instead of External GPU.
Clr CMOS, set everything to default values
test memOK button, boot up fine to bios, but still restarting as soon it goes to windows
try using fresh copy of windows OS (ext OS from my spare ssd), still no go.
so, any ideas what happen? do i mess something up? is there anyway to fix it? :'(
Btw my current built:
ASUS MAXIMUS VIII FORMULA Z170, updated to latest bios.
INTEL CORE i7 6700K 4.0GHz
8GB DDR4 2666Mhz Corsair LPz Vengeance
850W Corsair HX850W
500GB Samsung EVO 850
ASUS GTX 1080 Strix Advance Gaming 8GB GDDR5X
step i already did:
replace the PSU
850W Corsair HX850W
