My rig **is** cooling like I though it would!
a c i d.f l y
Austin, TX, USA
Old Temps:
Case: 41-45°C (idle to load)
CPU idle: 45°C
CPU load: 49-51°C
New Temps:
Case: 32-35°C
CPU idle: 40-42°C
CPU Load: 45-46°C
Changes made:
1) Added 35cfm 80mm fan to pci slots, cut out pci holders underneath AGP card and mounted fan as exhaust.
2) Lapped Heatsink.
3) Removed 80-92mm adapter.
4) Removed dust from fins
5) Connected Tornado directly to 'sink with zip-ties.
6) Cleaned off cpu (had old OCZ Ultra II crap all over the cpu.. man did I suck applying the last two times).
7) Did a 10x better job applying Arctic Silver 5.
Time taken: < 2 hours.
Sweet. :thup: :attn:
a c i d.f l y
a c i d.f l y
Austin, TX, USA
I don't think it was any one thing, but if there was one thing more than the others, I'd say the custom PCI exhaust... as case temps are hard to change. A significant drop in case temp will cause a significant drop in CPU temp, regardless of the heatsink you're using... so yeah, that one.
-Frank
::EDIT::
HURRAH! FIVE STARS! :D
sagitta85
Now if you can wack off another 10C for your case, that would be sweet....
(looks at his sig) :D
Radical
CA
Your case temp was only 4C cooler than your CPU temp when idling? Does that seem weird to anyone else?
a c i d.f l y
a c i d.f l y
Austin, TX, USA
Yeah, it was weird to me as well. I'm guessing the temp reader was in a completely uncirculated spot close to the processor.
In any case -- things seem normal now!
I'll take pics as soon as I pick up some AA batteries for the digicam!
-Frank
