My Sytem Build
SRB442
Western New York
My System Build
First of all thanks to everyone that has gave advice on this build. I have built several pc's but nothing like this. My specs are.
TT Xaser III case with 420 watt power supply
Asus P4C800-E MB
Intel P4 3.0c
2x512 Mushkin 3500 blk level II
ATI Radeon 9800 pro
So far the system is running at 3.6GHz (20% overclock), FSB is 4x240 MHz, Memory Bus Speed 2x160 MHz. I tried a 30% overclock and the system won't boot to windows (stock cooling). I took the memory off auto in bios to look what was there. The numbers are cas# latencey 2.5 clocks,ras# precharge 4 clocks, ras to cas delay 4 clocks, precharge delay 8 clocks and burst length 8 clocks. Are these numbers ok or there changes I can try? I would like to tweak it some more but not kill it. I just checked my cpu temp and was 33c through asus probe. Steve
attack
That is a very very nice rig! I would set your CAS to 2, and other settings try for 2 3 3 3 with a 1:1 ratio, if it doesn't work, loosen timings until it does. If you can't get it to work at cas 2.0 with a 1:1 divider use the 5:4 divider and run 2 2 2 2. Also checkout the memory section they can give you more info than I can about taht setup
SRB442
SRB442
Western New York
Thanks for the comments on the new rig. I still don't undersand all the overclocking stuff. I have changed the timings to 2,2,2,5 and set to ddr 400 and stuff but the only way the cpu will show higher than 3.0 is if I set the cpu to a 20% overclock. I will learn this eventually. Steve
CamH
Oregon
You're running your RAM at a really low speed. You shouldn't have much trouble running it 1:1.
