- Jul 8, 2002
- Northern KY
alright. here i go.. i got this xp2100 a couple months ago. it's agoia. ever since i got it, i have had a temp prob. first with the stock heatsink and fan my pc would not start. asus cop would stop me from frying it.
so i looked around in search of the best heat sink on the market. enter the slk800. so i got that beast for 50 bucks and was able to setup my rig.
however my temp was at 48C idle and i had crash probs. so i set my chip to 1.3ghz to eliminate crashing.
next i got artic alumina. That brought the temps down only a little. about 3C. and i tried applying it 3 different times. all the same result, but i eventually could run at 1.8ghz most of the time.
so today i put on a thermal pad and I got a couple of degrees lower. still having probs. attempting cpu arithmatic in sandra i cannot do. i overheat and shutdown.
i have one 80mm smart fan2 for intake and two vantec stealths for exhaust. also a hdd cooler in the top bay for exhaust.
with mbm my idle temp at 1.8ghz is about 60C.
in bios and pcprobe it is around 46C
about 3 times i have had the error system failed cpu test for no reason. 2 of them at boot and one during windows.
who thinks i just have a bad setup and who thinks this chip is garbage?
