- Dec 4, 2016
Finally finished my T-900 Build! This was my first time bending PETG tube and my first all water cooled setup. I am an electrician and bend PVC and pipe on the reg lol. I hope you guys enjoy the photos and also thank you for the comments and advice in previous threads.
Watertcooling & lighting specs:
Thermaltake 900 Tower (Black)
EKWB HDC Fittings and some XSPC fittings (that I ran out of EK's)
EKWB GTX-1080 GPU water block with black back plate
EKWB CPU EVO Supremacy water block
Ball drain valves on both pumps/resi's and rads
EK-Coolstream XE 480 and 240
EK-Cable fan splitters/extensions with speed signal
EK-HD PETG Tube 10/12mm
EK-Vardar F4-Fans (120's for rads (x6) and 140's for case (x4)
Mayhems Ultra H2o, UV Dye & Biocide
CableMod WideBeam Foam Adhesive LED Strip UV - 60cm / 30 LEDs
Thermaltake Pacific PR22-D5 Silent Kit Reservoir/Pump Combo (x2)
System Specs:
EVGA-G3 power supply 1000w
MSI X99A Godlike Gaming Carbon Extended MB
Intel i7-6850K
Nvidia GTX-1080 Founders Edition Graphics Card
32GB Corsair Vengeance DDR4 3200 Ram
Intel 750 PCI Express Solid State Drive (800GB)
x2 PNY CS1311 960GB Solid State Drives
Overclocked to 4.4Gz stable
System Specs:
Intel i7-6850K
