refridgeration..
so there i am sitting through another briefing(Stupid air force) and im thinking about this rather small refrigerator i saw at walmart last night...i mean small like maybe a 15"X15" cube. it had enough room to hold a radiator and a 6 pack..okay maybe a 12. anyway it had a little tray it used to hold the ice it made. i was thinking of fabricating a new larger tray for that section to hold the radiator. I know this is possible but i just don't understand the logistics behind it. i mean it would be way colder than room temperature so im afraid of condensation forming on the tubing and possibly hitting components.i could make the rig easily with the tools we have at work..maybe take me one hour to make the tray and the waterclocks. okay 2 if im having an off day on the cnc or the welder for that matter. but anyway id drill some holes in the side of the fridge and weld a fitting to the fridge. then on to the radiator. same thing on the way out.putting the rig in the pc shouldn't be too hard. taking everything out and running all the wires.yay all 10 fans will be gone.less wires. but im still concerned about condensation on the tubes. is this a problem? should i even worry about it? what kind of pump would i need to run a rig like this. an eheim 1250 or something?theyd be right next to eachother on the desk.. ...ack okay im rambling...goodnight
