My uber n00b RAM Question - Need quick answer
s00t
JonSimonzi
Yes, that's perfectly compatible, and very good ram. I was going to suggest G.Skill Ripjaws :)
S
s00t
Wait a sec.... it says in the specs for the i5-750 "Memory Controller: Dual channel DDR3 800/1066/1333 MHz". <- So this 1600 MHz RAM won't work with it?
Please help.. I don't want to have to overclock the CPU to use the ram..
Bobnova
Senior Member
Officially, nothing faster then ddr3-1333 exists.
In reality, things are clearly different.
1600 shouldn't be an issue at all for an i5.
S
s00t
I just hear a lot of issues with 1600 mhz ddr3 with i5's around the place, I might just stick with a good set of G.Skill 1333, that should be fine considering I'm not overclocking the CPU. Correct?
Bobnova
Senior Member
The performance difference is minimal, especially if you aren't overclocking.
Bobnova
Senior Member
The slower timings (8-8-8-24 rather then 7-7-7-21) will hurt a bit, but again not something you'd notice without specifically testing for it.
S
s00t
So are the faster timings worth the extra £7 + wait? Considering this is gaming rig I wan't to last many years.
Falseprophet
Ogden, Utah, USA
I dont know what your suppliers have in stock, but I shop at newegg since my best friends uncle owns a computer business and orders his parts from newegg or a different vender if he is placing a LARGE order worth several thousand $$$. I have 8G of G.Skill in my computer and noticed what your looking at is 8-8-8-24, newegg also offers the same style ram with 7-8-7-24 timings for the exact same price. I have played with timings and MHZ a bit, running DDR2 1066 5-5-5-(12&15) and changing the clock to 750-800ish 4-4-4-(11&12) I would take the faster MHZ and tighter timings, then you have your cake and get to eat it too!!! I have also read that INTEL setups favor faster MHZ on the RAM vs lower timings, but it looks to me to be a close margin when you weight and bench them! I would take the higher MHZ and LOWER timings in a hearbeat!!! BTW GSkill is awsome stuff for the money in my opinion p.s look for the 7-8-7-24 stuff if you can find it from one of your suppliers here is what I was talking about, http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303 they also list the 8-8-8-24 stuff you looked at for the same price
