- Sep 26, 2002
- Indianapolis, IN
i've seen a lot of posts about people saying that their voltages are too low in their motherboard sensor programs. the one thing that people should remember is not always how your voltages look all the time. it's more or less if your system runs stable. many people will look at their voltage and think that if it isn't right on the dot, there is something wrong. for example, in my system, i used to have a different psu. the voltages on it were pretty normal, all well within tolerance. the only thing was that my computer would constantly restart. it did this for a long time and i couldn't figure out why. i tried a ton of different components thinking that something was bad and causing my restart. after finally figuring that it could be the psu, i replaced it. after that, my system ran rock stable. a while ago i decided to check the voltages in the onboard monitor. i noticed that they were actually all pretty low, except my +5V which was high. they were a lot lower than with my old psu. they are all barely within tolerance, but it really doesn't matter. the thing that you should learn from this is that your onboard sensors don't always tell the story, it is more or less if your computer is stable or not. if you want to be sure that the voltages are low, get a quality meter and measure them yourself. that is a way to ensure that they are fine if you are that worried. i just figured that i would get that out there. just remember, voltages don't matter that much unless you are actually having problems! it's just like the old saying, "if it isn't broke, don't fix it"
just my take on it...
