- Apr 10, 2001
Some had asked me about this. Here is the article with pics.
Please post any questions here so that all may benefit.
wild_andy_c (Jul 24, 2001 03:49 p.m.):
That is one excellent piece of writing. I will say no more. Hold on I will. That is brilliant. Well done AMDGuy.
sifu quoc (Jul 24, 2001 11:53 p.m.):
i was wondering if you were folding??? cuz there is someone named AMDownz that is folding for the wrong team....
just asking...
AMDownz (overclockers.com)
instead of
AMDownz (www.overclockers.com)
Colin (Jul 26, 2001 01:41 a.m.):
What do you want to know about the HIP6301CB?
dozier768 (Jul 26, 2001 01:20 a.m.):
hey amdguy where did you find info on the hip6301 because i have an hip6302cb and i cant find any info on this soic i'd really appriceate it if you'd let me know
AMDGuy (Jul 26, 2001 07:31 a.m.):
I just did a search for hip6302 on www.google.com and found this http://www.intersil.com/data/fn/fn4/fn4766/FN4766.pdf
Hope that helps. It looks like the same basic chip.
Gus (Jul 26, 2001 09:16 p.m.):
Thanks much! Now if I can work up the guts to void my warranty! What do you think? I got a T-Bird 1.0 ghz overclocked to 1.5ghz. I should be happy I know! But will doing this voltage Mod get me to 1.55, or even further 1.6ghz? How bout going with a 1.2ghz? Will that get me to 1.6 or 1.7? Pretty good with a soldering iron. I bought the same one from Radio Shack you did, but it was to turn my Promise Ultra 66 into a Raid controller. To which I haven't done just yet. Got problems trying to upgrade the BIOS on it! But thats another story.
Layout:
Abit KT7a
1.0 ghz 266mhz T-Bird
Overclockerzstore PC133 ram Enhanced 256mb.
Enermax 430 Watt PSU
Radeon 32mb DDR
IBM 20 gig 7200rpm Deskstar
BeCooling Maze Waterblock w/ Lexan clamp
WaterWetter
Rio 180
3ft. of coiled copper tubing tie strapped to a 12-inch household fan (radiator) Got idea from this site! Under Radiator Alternative, in tips and techniques
Coleman 6-pack cooler (resevoir)w/ ice pak
AMDGuy (Jul 27, 2001 08:03 a.m.):
Layout:
Abit KT7a
Radeon 32mb DDR
WaterWetter
Rio 180
I'll assume you're at the max stock voltage of 1.85V now. I'd say you can get 1.6gigs out of it with the mod but you'll need to really watch your cooling. I'd try not to go much over 2.0 V.
