- Nov 6, 2004
I am curious if my new watercooled rig is achiveing it's optimal temps... The rig is also OC'd a bit as you can see in the below pics... Attached are some pics showing the temps of system in an unloaded idle state and in a heavily loaded state. Let me know your opinions and or feedback.
Below is a rundown of my Rig and the link to pics of it......
MOBO: MSI K8N Neo2 Platinum
CPU: AMD Athlon FX53 Stepping A REV. SH7-CG WC'd by lapped dangerden RBX Artic Silver 5
Memory: OCZ 3200 Platinum Rev2 2x512 2-2-2-5 in slot 1&2
Video Card: Ati Radeon x800 XT PE shim removed & WC'd by lapped D-tek GPU block Artic silver 3 & Lapped ramsinks added to all 8 GDDR3 chips.
HDD: WD Raptor 74Gb on SATA port 3
Sound Card: Soundblaster Audigy 2
Power Supply: Antec Truepower 550
Case: lian-li PC65
Radiator: danger den Double Heater Core cooled by 120mm panaflow
Reservoir: custom res....
Pump: Eheim 1250 @ 318Gph
N-force is cooled by lapped vantec copper orb
Coolant = Distilled water + water wetter + green dye-lite
Pics of my rig can be found @ http://thematrix.homelinux.com/Pix/pix.html
(disregard the temps in the two screenshots the temps in those are with me chilling my rig and water with 15F outside air)
Case: lian-li PC65
